It will work on any soft sided pool, with adjustments for the height of the pool. Or possibly a metal frame Intex type.
The varying depth vs top rail (inflatable ring + soft side) is dependent on the pool itself.
I won’t die like that;;NO DIVING in Intex Pools!!!!! None of them are deep enough.
NO
NO!!!
It is deep enough to swim laps.Does the Intex 18*52 pool deep enough to swim (
Bigger pump is always better. I'd go for something closer to 1000gpm if you can.
Can you show us your choices? Just paste in the URL.
Haha, correct. EXCEPT when you're talking about the ridiculous little cartridge pumps that come with the Intex type pools.I'm sorry, but a bigger pump IS NOT always better.
The correct size pump is always better.
The "big" paper filter one that came with my pool was plenty and I used it two years, well I cut off the paper filter and used a 175# sand filter
That little pump pushed through a sand filter? wow! I never thought of that. The other day when I thought I burnt up my pump I was ready to dig out that toy pump and filter that came with the pool and use it to keep the water circulating until I could get a new "big" pump.The "big" paper filter one that came with my pool was plenty and I used it two years, well I cut off the paper filter and used a 175# sand filter
What would be a good temperature for swimming healing
