- Apr 22, 2019
- 424
- Vinyl
- CircuPool Core-55
Thank you for the drawings. So, that pipe on the left is my return water pipe? Things I should already know... lol.I would use the vertical install kit and go up after your pipe comes out of the filter.. Put the flow switch right of the outlet.. "your supposed to put the flow switch after a 12 inch straight section but I do not and it works fine"
This way with the install kit
This way without the kit, I am not sure if there is enough room so you would have to measure..
