Bover907 is correct, the air pillow is an "ice compensator", and it is for the water on TOP of the cover, not in the pool. Because water, ice and snow will build up on top of the cover, the weight and pressure will continue to push on the cover near the edges of the pool. My brother in law didn't use one and the ice pushed out his sidewall and he needed a new pool. The pillow allows for the ice and snow to compress in towards the pillow, alleviating some of the stress on the cover and sidewalls of the pool. As Bover907 mentioned, The Pool Pillow Pal helps float the cover in place on the pool and keeps the pillow centered. Also, Hel2002002 said the deflate, which they do. If if "pops" due to pressure of the ice, it did it's job, but if it leaks or deflates, it can become useless. I used and Air Valve Sealer which is on Amazon to seal the valve of the pillow.
