Good day everyone!
I recently got a house with a pool in Phoenix, AZ. When I got the house, it took me a month to move from Texas, so I got a Pool guy to clean the pool while I was away, who ended up letting the pool turn green. The guy installed new DE Filter grids since the filters had some holes and broken ribs and he gave up after a couple of days when the pool was really green due there was a lot of debris and algae and it required someone to backwash and take care of the pool closely.
When I started taking care of the pool the PSI was quite high ~30 PSI, I think the circulation of water (suction/return) was just fine. I needed to clean up constantly the filter since there was too much algae, and that I thought that algae and debris got the pressure of the DE Filter that high.
That same week, after I had shocked and cleaned my pool, which got it to a cloudy level without that greenish color, on the day 4 I believe, the flow just decreased significantly to the point that there was barely water returning to the pool. I got a pool cleaning company to come look at my pool, and they basically cleaned up the DE Filter grids again, and the pressure went again down to around 8 PSI, but after a couple of hours it went back to ~30 PSI again.
They recommended me to remove the DE filter grids which I did and the pressure stays at 8 PSI steady, it is just when I put the DE Filter grids back that the pressure goes back up to ~30 PSI. The filters have the DE powder and it has the right amount for the sq ft coverage. And the filter grids are not green like before when I just got rid of the algae and debris.
All the basics have been looked at (clean up filter grids, skimmer baskets, leaks, clogged impeller, DE powder, etc) and now that company seem to be stuck as well, and they recommend to install a Cartridge filter but I am afraid that that might not be the right thing to do.
Any recommendation?
At this point we ran out of ideas and I don't know what causes the high pressure which kills the flow of my pool. Like I said, the filter grids are a month old and the brand seem to be decent (Pleatco)
Any recommendation?
