When I flip my pool to spa mode, the return valve actuator tries to turn but gets hung up in a number of places and starts clicking loudly...I can force it (gently) the rest of the way around with a little manual pressure, and once in spa mode the same things happens going the other way when I try to get back to pool mode. Video linked below. Something stuck in the valve? Motor issue? I took the top off the actuator and the motor itself seems to be working, so I'm not sure whether the microswitches are the culprit here or not (they seem to be a common point of failure based on the cursory reading I've done). Hoping someone can set me in the right direction...thanks in advance!
Jack
Video - Clicking Actuator
Jack
