How much should it cost for parts and labor to replace 1c40. I have a pool company giving me a quote of $1750.
thanks. I think all you do is take it out like you were going to clean it and replace it back. Is that correct? Right now I do not have a connecioin to my screenlogic. Will this take care of that also?If replacing just the cell, do it your self. Very easy. We can walk you through it.
You can get a replacement cell for about $1000. Contact Marina Pool in Denver, Polytec Pools in Las Vegas.
does not recognize salt cellThat is all it takes. You need to power down the entire system when you unplug the old one and plug in the new one.
The Screenlogic can be different. What is that issue?
Not sure. I can control pool cleaner and other devices from the app, just not salt cellThat can be a few different things. Do you have other RS485 connections (remote, antenna for Screenlogic, pump, etc) that are working?
Hc,
That does not sound like a cell issue at all.
I assume you have an EasyTouch is that correct?
Did it every recognize the cell???
Tell me how you can tell it does not recognize the cell.
Does your ScreenLogic show the following page?
When you adjust the output % using ScreenLogic, does the output on the cell change?
Does does ScreenLogic tell you the salt level?
Tell us more..
5 yrs old. Not producing chlorine always been connectedHc,
Did the cell ever have a connection to ScreenLogic??
If not, replacing the cell will not make any difference.
Why do you think the cell you have now is bad???
How old it the existing cell???
Also, no lights.5 yrs old. Not producing chlorine always been connected
What is wrong with actuator? Most can be repaired, if you are handy.Also, the actuator needs to be replaced at a cost of $375 cost and labor. Does either of these prices sound reasonable?3
