I'll try to keep it short.
I have some large areas of staining that I suspected were from copper.
My suspicions are driven by the kids hair constantly turning green, as well as a spot test of a vitamin-c tablet having black color reaction with the stains before eventually disappearing.
I know what the cause is, and it's since been corrected. I was using an incorrectly calibrated PH meter for about 3-4 months last year. It dawned on me after seeing a blue/green substance in my filter.
I did the PH drop test with my TF100 and realized I was running the PH in the 5.7-6.8 range the entire time. (Ok lesson learned, and I'll only use the drop test from now on).
Here's my question. Obviously the copper was introduced from the heater coil as I have no other sources of copper including the city water.
I took the manifold off to inspect the corrosion damage.
Honestly, I think it looks "ok", the copper is nice an thick still but there is some red discoloration on the insides of the tubes.
I've reached out to Jacks Magic for support on the stain removal, but they are concerned about the Red Tint in the copper.
Should I run this coil out of it's remaining life or replace it? The heater is about 2 years old.
Also I understand a drain & refill is the only way to remove the copper so that will be on my list as soon as I get rid of the staining.
I'd love to hear your thoughts on the condition of the coil.
