Our plaster contractor installed a pool jet fitting on the side vacuum line instead of a vacuum port fitting. This was not discovered until the pool was filled with water.
Our contractor has gone awol and we are not sure what is going to be involved in correcting this. Before I start looking for a new contractor to fix the error I want to educate myself. Are we going to have to drain the pool to remove the jet fitting and install the vacuum fitting? Will we have to remove plaster/tile to correct this mistake? Any chance this is an easy fix?
Thanks for any insight that is offered!
