- Oct 25, 2015
- 5,182
- Plaster
- CircuPool RJ-60 Plus
An OCLT requires no chlorine added. So you really don't know your OCLT reading unless you ran with the swg off last night. TFP methods work well because there's no guessing. When we try to guess it usually doesn't work out well. Now that you have the liquid chlorine you have more flexibility do really do this according to the procedure.
I just read your post about contacting Circupool. Pool Math is in agreement for what it's worth. Remember my previous post that said 12 hrs at 100% is 5.3 ppm. Pool Math indicates 12 hr at 75% is 4 ppm added. This is right in line with maximum typical pool FC requirement and it can even go a little higher than that in extreme cases.
Pool pump run times are not based on turnover. It's a long debunked myth still used by some "so-called experts" to size pumps and estimate run times. You run long enough to get the required chlorination and beyond that to clean the surface and bottom of the pool. Often this is way less than one turnover and sometimes way more is needed; so turnover is just not the right approach.
I would follow Circupool's recommendation since if you need a replacement continuing to work with them will shorten the process. If they end up replacing it you may be able to do so quickly since I think their main office is near Intercontinental Airport... close to you I think. If not replaced we can continue with liquid chlorine and eradicate whatever is consuming your FC with a SLAM. Then follow up with a real OCLT. While this is going on your pool should be safe to use. Please see the SLAM video below and the OCLT procedure hereOvernight Chlorine Loss Test when needed.
I hope this helps.
Chris
I hope this helps.
Chris
