- Jan 4, 2016
- 5,288
- Plaster
OK, a few things. The liquid stabilizer does not require 24/7 pump running to mix - an hour is fine.
Do you now have two packets of dichlor left?
Yes, the chlorine is too low in the mornings, so we do need to be concerned. You mentioned that you added 4 lbs of dichlor today which will bring the FC up quite a bit. If that was 4 packets of 12 ounces each, let me know and I can adjust my numbers.
