My Valves are no longer turning correctly.. Is there an alternative that buying new valves ? Can these servos be repaired ? Any help would be appreciated !
A Pentair CVA-24 actuator will replace a Compool. I believe Pentair acquired it from Compool.
There are limit switches in them that sometimes fail. Folks have opened the actuator and cleaned the switches or replaced them to get it working. It is probably either a limit switch failure or the motor failed. Likely a switch.
I have a set of Compool CVA-24 actuators on our 12-year-old pool, and recently had one of the two quit working completely after our kids used the spa. I took the cover off of it and managed to wiggle the gear enough that it tripped the microswitch and the motor turned on, after which I was able...
My set up: In-ground 10K-gallon Gunite pool with attached spa; all Pentair equipment and valves. After about two years of operation, the Pentair valve actuators that switch my valves between pool circulation and spa circulation sporadically got stuck in the pool or spa position. After reading...
