Last week I had a new heater installed for a connected spa/pool with a single pump. There was no heater installed when we moved into the house 6 months ago.
The heater is a 260k BTU gas heater that will be only used to heat the spa. To heat the spa exclusively, I should be able to move valves to ‘spa return’ and ‘spa suction’ to run the filtration exclusively through the spa. However, once I move the valves, the water level rises and the spa spills over into the pool.
As the spa spills over into the pool, the spa water takes much longer to heat.
I can confirm that water does not appear to be going into the pool and that water is not flowing through the pool skimmers.
Is there a valve I’m missing? Is the spa suction not working? Hopefully someone can help point me in the right direction. The installer and heater distributor have been no help so far.,
