I have a set of Compool CVA-24 actuators on our 12-year-old pool, and recently had one of the two quit working completely after our kids used the spa. I took the cover off of it and managed to wiggle the gear enough that it tripped the microswitch and the motor turned on, after which I was able to get the valve to the position I needed it in order to operate the pool. My question for the experts here - are the microswitches the only real wear item on these actuators? I can buy a set online, but I don't see anything like a "rebuild kit" so I am assuming the microswitches are it. I found this schematic and it shows the little arms that ride on the cam to be obsolete. I didn't look closely when I had it apart to see what was causing the problem, but I'm hoping that one of those isn't broken. Since the motor ran, I know it's not a problem with the motor itself.
As long as I'm here, I would also love a link to a tutorial video for rebuilding these if you know of one. I searched the forum and YT but didn't find anything exactly addressing this issue. I found one that a lady disassembles and adjusts the cam arms to make the valve stop in the right spot, but it was so hard to watch I couldn't even finish it... it is truly amazing how spoiled I've gotten with all the good self-help videos that are available online now. If any of you have done one, please share...
