Cloudy persistant water
Mctwist937
Active member
Jun 5, 2016
37
Orange, CT
Hello -
I opened my pool last weekend, it was pretty green but turned blue and cloudy within 24 hours of slamming. It has pretty much remained the same, its still quite cloudy. I can't get it to clear up so any tips would be appreciated. Here is my current levels. Wondering if i just keep going or if theres something else i should try. Thanks.
FC - 24
CC - 0
CYA - 40
pH - was 7.2 before starting
TA - 60
Sand filters are slow. When was the last time it was deep cleaned? Has FLOC ever been removed through it? You could try using enough pool DE to raise your filter pressure by 1psi, then be prepared to babysit as filter pressure should rise quickly after that. When pressure reaches 25% over baseline, backwash and repeat with new DE.
If needed, here you go.
