*EDITED*
Greetings,
So far, 12 gal 12.5% Shock, 4 bags 68% Shock.
Next steps: Purchasing a FAS-DPD kit arriving today. Replace filter (I have a backup), Try a SLAM
Pool Specs: In ground | 33,000 gal | Vinyl | Cartridge | Tightly Woven Mesh Cover for Winter | Chlorine Sanitization
Background:
Opened pool Sat May 29th. Greener than expected. First few days a part of the cover had the main drain covered (I suspect). I found the cover moving on the bottom while scrubbing when I had the pump off. The green went away nevertheless, but was very cloudy.
Testing NT-Not tested | (Me)- home test | (St)-store test | ?- no record/forgot/maybe inaccurate
Day 1 5/27 ---------------------------------------------
FC - 0
TC - 0
CYA - 0
Alk - 120
pH - 8.2+
Phosp - 0
FC - 10+
pH - 6.6
Phosp - 0
FC - .5
TC - 3
CYA - 0
Alk - 80
pH - 7.2
FC - .13
TC - .13
CYA - 35
Alk - 103
pH - 7.2
Ca - 177
FC - 0
TC - 3
Greetings,
- Need some encouragement/help...keep shocking or SLAM? My kids are going to make me walk the plank soon...
- Note on pictures: Pictures are chronological; Picture 3 is at dark dusk; Lots of seedling/leaf debris that gets cleared 2X day
- 3X vac to waste
- 2X cartridge rinse
Background:
FC - 0
TC - 0
CYA - 0
Alk - 120
pH - 8.2+
Phosp - 0
- Action: 8 gallons 12.5% Cl, 80oz Muriatic acid
- Strenuous scrubbing
FC - 10+
pH - 6.6
Phosp - 0
- Action: 4 lbs Borax
- More scrubbing
FC - .5
TC - 3
CYA - 0
Alk - 80
pH - 7.2
- Action: 7 lbs CYA, 4 bags 68% Shock
- More scrubbing
FC - .13
TC - .13
CYA - 35
Alk - 103
pH - 7.2
Ca - 177
- Action: 18lbs Calcium, 4 gal 12.5% Shock, 4 bags 68% Shock
FC - 0
TC - 3
- Action: Ask TFP for help....!!!!!!!
