Hi-
I had a very green home pool which is now in super condition thanks to my following your forum.
I'm trying to take care of a pool at our vacation rental house in a similar way, and It is much harder because I can't take the pool out of service very often. The house is quite booked, and is only open for between 24 and 72 hours at a time for me to work with. it is also hard to drain the pool too much at a time, because I can only fill it
pool is 9,500 gallons plaster. Temp is likely in mid to high 80's (can get more info when I am at the house later)
Most recent test two days ago had ph at 7.4, Alk at 110, CYA at 110, Calcium hardness at 400 (our tap water is around 250, so thats not too bad) Nitrates at 30.
House was empty for 48 hours a few days ago, so I added 2 gal of 10% liquid chlorine at night around 10 PM, and went home so didnt get to test after (pool was reading about 1ppm FC) . When I returned to the house the next day, at 4 PM the pool tested with 0 ppm free chlorine. ( I was using FAS-DPD, which seems accurate at our other house.) by my calculations that means it went from about 20 FC -> 0 in 18 hours!!
Asked at Leslies pool store nearby and they had no idea. The only thing I know is that the people staying at the house had a party (against house rules!) and possibly much peeing in pool.
So two questions - I have people staying in the house for the next 5 days or so and need to keep chlorine levels up maintained. How to do this properly without visiting the house daily?? I'm planning to go add some Liquid chlorine right away again and stay at the house for 30 mins to see what happens.
But for the next 5 days, until I have the house next available without tenants (for about 3-4 days) I need to sanitize it best I can, and keep chlorine levels stable so current tenants can swim.
I'm wondering if I can put Calcium hypochlorite in a thin sock in a pool float chlorine dispenser so it slowly dissipates.. so I don't have to visit the house daily (people on vacation dont like to be disturbed daily.)
Then I can just come every two days to refill... Or should I just use the dichlor tabs which will increase CYA for now, expecting to have to do added draining in a few days.
Second.. What could be the cause of the FC levels dropping so rapidly - the pool is clear, as I said with small amount of algae - maybe 4 spots with a line on wall of about 4-5 inches.. looks like a dark brownish/greenish scratch.
Thanks.
By the way there is a small amount of visible algae on the walls of the pool.
Thanks.
