Chlorinator low voltage
My salt level is 5000 I usually keep it at 3000 but I was traveling and had a pool guy care for it for a month. Does high salt ruin the chlorinator?
It can damage the system.
Why is the salinity at 5,000 ppm?
How are you getting that number?
Don't operate the system with the salinity that high.
Get a K-1766 salt test kit.
How old is the system?
What are the first 7 characters of the box and cell serial numbers?
The voltage is low, which can be low input voltage, a bad transformer or maybe bad rectifiers.
Check the input voltage, the voltage from the transformer and the voltage from the rectifiers.
The board might be misreading the voltage.
Check the configuration menu to see what cell type is selected.
Make sure that the cell type selected matches the actual cell type.
Check the salinity with a K-1766 salt test kit to see if the salinity reading is accurate.
I always keep it at 3000. I had a pool guy for a month because I was traveling and now it’s reading 5000.
I’m getting that number from the display. I’m the system is just under 3 years old and I don’t have a salt test kit.
