No, we are not.Using copper algaecide, by chance?
When they tested and printed out the results, EVERYTHING came back at 0 except Stabilizer.
There's no way that the calcium level was zero. The people testing the water have no idea what they're doing.Why would the calcium hardness be 0??
We are using an in line chlorinator. We are usually set at around 2.5 with 5 being the max. We didn’t shock often during the winter but kept chlorinator stocked. We planned to start shocking weekly again in addition to the tabs when this all happened.Wow..... no free chlorine yet the pool store is worried about calcium? I would have suggested that such warm water better get some chlorine in STAT or you're inviting algae to the party.
Just an example of why we DO NOT TRUST POOL STORES with our pools. They're wrong more often than right, and without you having your own way to monitor and test your pool you're clueless to the damage they can cause you.
How are you chlorinating that pool? You *are* using chlorine, right?? Not Baqua or some crazy Ozone or UV device??
Maddie
Can you tell me more about the ”heat exchanger”? When you say excessive use of tabs are you referring to the chlorine tabs?It's definitely copper.
If the pH and TA came back as 0, your heat exchanger is being destroyed.
Most likely, excessive use of tabs has caused the problem.
When you say TA is that the alkalinity? I apologize for all the 4th grader questions. New to all this.I had replied before the threads were combined so only saw the pictures, but I agree with James. I have seen this exact thing after a TA crash acidified the water and destroyed a pool heater.
I do not know the answer and the pool store said that rarely see 0 in results for calcium.Why would the calcium hardness be 0??
Well, it appears we did the recipe for disaster. Not sure what to do now.pH increaser is a bad choice, especially if you are adding calcium at the same time.
Adding sodium carbonate and calcium chloride at the same time is a recipe for disaster.
A better way would be to use baking soda until the pH was ok and then slowly increase the calcium.
The heat exchanger is a coil made of copper that the water flows through while the natural gas is burned around it to heat the water. Low pH (and if your TA tested 0 your pH was 4.5 or lower) will eat the copper exchanger putting the copper in the pool water resulting in the blue you are seeing.Also not sure how to check the heat exchanger referenced?
That was a helpful, thank you.The heat exchanger is a coil made of copper that the water flows through while the natural gas is burned around it to heat the water. Low pH (and if your TA tested 0 your pH was 4.5 or lower) will eat the copper exchanger putting the copper in the pool water resulting in the blue you are seeing.
Your extended use of trichlor (pucks, tablets) and not testing your pool water chemistry turned your pool water into an acidic stew.
The low CH (which I doubt could be that low) will not effect the gel coat of your pool.
Correct.When you say TA is that the alkalinity?
