- Jun 12, 2023
- 163
- Plaster
- Hayward Aqua Rite (T-15)
So my levels are here below. My CH actually went down from the last time I checked it. Previously I was told that there was no need to add any CH as by end of summer it will go up on it’s own, but my levels have stayed between 225-250 since Feb when I added the CH initially given that my first fill water only gave me a 50 level CH. Is that advice still solid or should I add some?
My CYA was 60 . Since temps next week are back in the 90s, should I look to add more CYA to get it a little higher or still wait?
My pH is always high, but I guess that is going to be the case all the time until next year with new plaster. I have to add muriatic acid at least every other day. Is that fairly normal?
Suggestions from you pool pros always welcomed and appreciated!
