- Jul 3, 2019
- 423
- Plaster
- Jandy Truclear / Ei
When do you know it's time to replace a cartridge filter?
After I clean the filter and pump basket, my pump always shows 14 psi. This morning after cleaning the filter, I put everything back and kept the filter out of the housing. The pump was showing 14 psi. Is this normal? I figured the PSI would have been lower since there was no filter for restriction?
