- Jul 8, 2019
- 86
- Vinyl
- Solaxx (Saltron) Reliant / Purechlor R5
I've had my pool for a few weeks now and have no reason to believe I'm at the point that I need to clean my cartridge filter, but I have questions after installing a fountain and seeing that the filter pressure changes based on the flow through the fountain/bypass unit. When the pump was new, pressures were 2psi and 14psi at low and high speeds but now I can get pressure as low as 2psi at the high pump setting since the fountain unit has such a larger opening than the standard eyeball return port.
So I guess the question is, with such low restriction obtainable based on the adjustment of the fountain, how will I know when to service the filter? Should I put the factory return eye back on weekly or bi-weekly just to check my pressure from a know start point?
