I have a caretaker in floor system. And I have done a rebuild kit about two years ago. I recently had to fix up leak on my pool pump. After fixing the leak and restarting the system and purging all the air using my side returns i then switched to my floors. All of a sudden, the pressure in my filter skyrockets. And the infloor system does not work. As soon as I switch back to the side walls, the pressure drops to normal and the sidewalls move water. I’m at a loss. I cleaned the screen already. I backwashed. The in floors worked for a second and then shut off. I’m not sure why all of a sudden they would not be working.
They worked fine until I fix the leak in my pump. I don’t think the two are correlated, but I am completely at a loss.
