- Jun 24, 2021
- 15,906
- Vinyl
- CircuPool RJ-60 Plus
Is there an explanation as to why I'm not holding chlorine?To clear the pool of algae, you need to follow the slam process....Link-->SLAM Process
You can do it at CYA of 100, but it will take an enormous amount of chlorine.
It would be better to replace 40% of your pool water to reduce CYA to 60.
Algae is consuming it. You need to use the SLAM process to kill the algae, so your FC can hold.Is there an explanation as to why I'm not holding chlorine?
Thanks for that, makes sense. Then the obvious question is, why am I getting so much algae? It's my SWG not keeping up?Algae is consuming it. You need to use the SLAM process to kill the algae, so your FC can hold.
You need to maintain your FC based on your CYA. Answer here: Link-->FC/CYA LevelsThen the obvious question is, why am I getting so much algae?
Post up the make and model # of the controller and the SWCG cell.It's my SWG not keeping up?
Does your gauge go to 0 when you turn the pump off? If not, bad gauge. Might be worth a replacement anyway.filter pressure and / or backwashing? My pressure has raised consistently since my first summer, almost at 30 now.
Because your CYA is so high. Your CYA is binding up so much of your FC that it can't do the job of killing algae. That's why it would be so helpful to replace 40% of your water to get your CYA down to 60.Thanks for that, makes sense. Then the obvious question is, why am I getting so much algae? It's my SWG not keeping up?
Your FC is being consumed by UV (the sun) and by killing Algae.Is there an explanation as to why I'm not holding chlorine?
Thanks for this unbelievable explanation - makes a ton of sense (sorry chemists!)Your FC is being consumed by UV (the sun) and by killing Algae.
Think of the CYA more like a gatekeeper (the chemists here will be screaming inside their heads now) - the more CYA you have, the less FC molecules get to go attack stuff....which is why as long as you keep the FC/CYA ratio in balance, you don't suffer all the side-effects of high Chlorine. The FC is there, it's just not allowed out-to-play, and just sort of sits there, waiting
Now, during an extended period, eventually enough of the FC gets past the gatekeeper and dies killing the Algae, or by getting bombarded with UV - and you end up with no FC. With less CYA, this happens quicker, as more FC gets past the gatekeeper. If there is enough FC getting past the CYA, then the Algae never gets a chance to grow, and your pool stays shiny and clean. If there isn't enough, then the Algae can slowly take hold, as it's growing quicker than the FC is available to kill it, regardless of how much is 'behind' the CYA.
To kill off the established Algae, we need a lot of FC to get past the CYA, for an extended period of time. So, we can either put a LOT of FC in the pool, or we can reduce the CYA and let more of the FC past in a given period. Its a lot cheaper (usually) to replace the water to drop the CYA concentration, than to hold an FC level very very high for an extended period.
AutoPilot Pool Pilot Digital Nano+Post up the make and model # of the controller and the SWCG cell.
My gauge does set back down to 0 when the pump is off, but I will try to swap it anyway.Does your gauge go to 0 when you turn the pump off? If not, bad gauge. Might be worth a replacement anyway.
Backwash. Run the pump on high, not clean pressure. Test your pressure on high regularly, when it rises 25%, backwash again.
Understood! My pressure gauge is reading 28 consistently for most of this summer; started the season closer to 20. When the pool was first installed, it ran at about 8, but haven't been close to that value in years, no matter how many backwashes I've done.So you have a single speed pump?
Use the gauge, sorry. I used test to mean, run the pump on high and read the pressure.
Your salt cell creates 1.06 lb/day of chlorine, which would add 8.5FC if you ran it for 24 hours at 100% If you clear the pool, it should be able to sanitize your pool. It should be OFF for slam.
Exactly. Once the SLAM is complete (you've nuked all the Algae to the point it is undetectable), then you just need to maintain the correct FC-CYA balance to ensure it never comes back.After all is said and done, sounds like I need to find the right FC / CYA balance to allow for a clean pool but not over-chlorinated - how is that done?
