Hey all! Never owned or built a pool, but we're taking the plunge. Our PB is old school (as you'll see from the pic, where I tried to add where the sheer descents and bowls go) but reputable, so we're looking for any and all advice, especially on the equipment as it seems pretty dated based on what I've been reading here. We started off with a 3'->8' depth, but are concerned about dedicating so much to a deep end. Have 3 little ones for now 9 yo and under, so I think they'll be ok with a sport pool for now, but no idea what they'll like when they're older--and I'll probably have much bigger problems to worry about when they're teenagers anyway.
. We've been trying to learn as much as possible but feel like we're still in the baby pool of knowledge when it comes to pools. We're in Northern Virginia in case that matters.
Pool
Dimensions: 22' x 45' (but may extend to 50', since consensus seems to be you can't go too big)
Shape: Rectangle Sports Pool 3.5-5.5-4 with autocover--safety first!
Automatic Retractable Cover: stone cover box.
Plumbing (pool): Plumbing will consist of PVC Schedule 40 pipe, including two skimmers, two bottom drains, three returns, and automatic pool cleaner, lines run back to filter area.
Steel: Steel structure consisting of ½” rebar on 12” centers throughout pool with four #4 rebar continuous at beam. Depths over 5 ft. per engineered plans.
Structure: Structure to be pneumatically applied gunite. Mix to be industry standard. The thickness of walls to be per engineered plans, 6” floor, on a gravel base.
Entry: 22’ x 8’ tan ledge with three steps located in shallow end of pool
Plaster: Gray marblelite or Quartz
Electrical: Two color LED Pentair pool lights. Bonding of steel swimming pool structure. Wiring and electrical hook-up of filter system.
Filter: One 2-hp Pentair whisperflo pump, 420 Pentair cartridge filter, & Pentair Easy Touch with salt and Screen logic controls for automation.
Heater: Raypac 400,000 btu
Automatic Pool Cleaner: Polaris 280
Spa
• 9’ x 9’ raised 18” (veneer by others)
• 8 hydro-therapy jets
• Color LED spa light
• 2 hp blower
Other
• Two 4’ sheer descents and four Pentair square Magicbowlswith dedicated pump
• 3 Glo Brite lights & 3 bubblers at tanning ledge
• Automatic water level control (water source provided by others at filter).
• Pole, brush, net, test kit and indoctrination
Pool
Spa
• 2 hp blower
Other
