- Jul 20, 2017
- 249
- Plaster
- Pentair Intellichlor IC-60
Greetings! Long story short, we've been noodling on a pool for three (3) years now. We had to cut short our last design because we moved from PA to NY. We're finally into the design stage and very nervous and excited! I've perused TFP mostly looking for any oversights / mishaps folks have experienced. Digging won't start until August, but at least we've started the process.
We have 4 children from 3 to 9. Goal is to create a fun pool area that can accommodate my family and other kids and their parents. Really looking for input and any changes folks think we should consider. We know ZERO about pools. Attached are some design snapshots and a snapshot of our lot from above. Here's where we are, which already reflects some input from the great TFP posters.
Pool
Type - Gunite
Pool - 24'x38' (free form and not to exceed 640sqft)
Coping - Stamped Concrete
Depth - 3.5' - 8' (w/ 8' diving board)
Slide - Considering this in addition to a diving board (eek!)
Autofill - Not included, but we're considering adding this
Drainage - None (builder said most folks don't have overflow drains up here)
Interior - Altima White Plaster (will be changed when we get into material selection phase)
Steps - Standard walk-in steps, 6' bench in shallow end
Equipment
Pump - Pentair Variable Flow
Filter - Pentair Clean & Clear Plus 420
Heater - Pentair Mastertemp 400,000 BTU
Lighting - 4 Pentair Globrite
Sanitizer - Pentair IC60 Salt
Automation - Pentair Intellicenter
Controller - None
Cleaning System - None
Cover - Mesh Safety Cover
Plaster / Tile - Wet Edge, Altima White (will be changed when we get into material selection phase)
Construction - 3' light broom concrete w/ 4" compacted stone
Pad - 4' x 8'
Contract does not specify Skimmer, Water Leveler (maybe part of Autofill?), Drain, and Leaf Trap. Should these be specified?
Other Stuff
- Sonance sound system w/ Sonos amp around pool
- Electric and CAT6 run to pool area w/ wireless access point(s)
- Control4 automation for select areas (e.g., pool gate alarm, security cameras, etc.)
- 12x14 Pavilion/Gazebo to host a 6-person table
Pool
Type - Gunite
Equipment
Controller - None
Pad - 4' x 8'
Other Stuff
