Bubbles in Check Valve
Vukota12
97
New Jersey
Hi! I have bubbles in Check Valve with elevated spill over spa with slight less than normal in my opinion spillover flow. No discernible loss in water with skimmers filled halfway up and weir flaps working well. No bubbles in pump basket either.
12,
I'm sure it is just me, but I am not sure what problem you are trying to solve????
Is it a loss of flow issue with the spillover, or bubbles in the pool, or does the spa drain back into the pool or ????? :scratch:
What problem are you trying to correct?
I don't see a few bubbles in a check valve as a problem.
Jim R.
Valves are almost 2 years old and I have not
12,
Jim R.
Yeah the bubbles concerning to me as I thought bubbles =leak. I do notice spa flow isn’t as strong from returns but not seeing a big enough difference in spill over flow strength.
Backwash returned spillover to full glory. One more quick question. Have Jandy PDA aqualink how can I run the pool without the spillover running?
Do you have AUX3 free?
If not you will need to move what is on AUX3 to another free AUX relay.
Details on enabling SPILLOVER mode are at Jandy Aqualink RS - Further Reading
Review that and see how it fits your setup.
Reactions: Vukota12
