Clean filter pressure is 10 psi. Its jusssst a teeny bit over 10 like maybe 10.25.What is the clean filter pressure? What is it now after 2 cups.
Ok we are going to do in a second. FOR THE CYA, I cleaned everything with alcohol and read your instructions again out loud and to my husband too. We both did the test independently. We couldn’t see the dot at 60 so +10, it is 70 like I said yesterday. I wonder if my vials were dirty and I think I was holding it too high today, not waist height!!!Ok, then go ahead and add up to another cup in 1/4 increments and see what happens to pressure...I've seen some filters take up to 11 cups, to get 1psi, but I think that is anomalous...
Added another cup of DE, no change! Still 10ish psi.OK, good job. Having a second set of eyes always helps.
If you want to, in the future you can get a standard solution. It has 50ppm of cya in the water. Substitute it in the test for your pool water. Add the reagent and mix. Fill to the 50 line. It will show you what the endpoint should look like.
R-7065 CYA Standard 50ppm (2oz)
tftestkits.net
Leave your FC alone until the starting OCLT tonight. GOOD LUCK! Take care, clean, slow drops...let them drop from their own weight, both count drops so you don't miss any. After sunset and before sunrise! SWCG OFF!
How is the filtering going? You should take a picture 2x per day from the same location. You can compare for progress. You will see even minor changes.
Before 6:04 even if Sun hasn’t hit it yet?OCLT after 9:11 and before 6:04
Ok okYes. Them's the rules. Once the sun is up, UV is present. If you want to chance it, that is your choice. I want to pass this test! Ain't letting a 1/2-1 hour of sun ruin my OCLT...
Just annoys me we could’ve been doing this as early as 6/27 if it weren’t for our Crud contractor (who gave us zero direction after being asked WHAT SHOULD WE DO and telling him it was still cloudy long after he said it should’ve been clear). We missed the 4th & my bday on 7/5. It’s been in since DECEMBER! Ok, sorry. Rant over. You’re helping us now and we are very grateful!!!Yeesh! You are on DAY 1. Maybe I should link you to some of the two, three and four week slam threads.![]()
Sand filters take the longest to clear the pool of all filter types, even after you pass OCLT.
We'll get this.
I usually don't prescribe these until day 3-5, but I think you are the day 1 prescription type:
You are the Ted Lasso of pool care! Those pics were super motivational tho hubby said, “I can’t look. It’s too painful.”Can't rewrite the past.
Only fix the now, we can.
Teach you, and you will be queen of the pool.
Look at how much you have learned so far? You are even bonding with your hubby over CYA...whoda' thunk?
It does get easier. When you know, you catch it before anything happens. With SWCG, you are way ahead of the game.
I spend < 5 minutes a day on the pool at this point. SWCG up a little, SWCG down a little.
Mine has never seen algae in years since first/only slam.
Better to learn it right the first time, then you will know.
You will be proud of your accomplishment, and confident you can handle anything.
Review this once a day after taking the P.O.P pills. Link-->How Clear is TFP Clear?
Will ask hubby to do. I’m back at work today, and he’s WFH.Take a picture of your skimmer, so I can see water level.
Good job on the OCLT. A .5 loss on the FC is a pass for FC.
Yes 5 drops of R-0003 and yes 2 drops to clearThe 1 CC is still an issue. Confirm, after FC test, you added 5 drops of the R-0003, then it took 2 drops of the R-0871 to clear?
We just assumed bc we broke up a large patio to add the pool and the color is the same as the backfill dirt, and we haven’t added landscaping yet which would stabilize any erosion. We’ve been consistently getting gravel in the bot too.I'm a bit concerned about the sand and the white in the robot. It could be there is an issue with the filter...and it is allowing sand and DE to return to the pool. You said there was a bunch of construction debris/sand. How do you know this?
Will ask hubbyWhat does the white feel like?
Will ask him to do after running bot againWith a CSI of -.44, I doubt it is calcium, but for grins, collect some of the white from the robot and drop a drop of muriatic on it and see if it fizzes.
Ugh I will NOT be happy w contractor if this is the case bc I suggested this from the get go! Would not explain powdery stuff on steps though, would it? I will read up on how to do.I'd also like you to figure out how to put a sock on a return jet...put the sock over a return, and tie a string around the jet to hold it on if you can. I want to see if the filter is returning material to the pool.
Yes will ask hubbyCan you also some pictures of your equipment pad, so I can see all the equipment and valves.
