- Jun 24, 2021
- 16,041
- Vinyl
- CircuPool RJ-60 Plus
If they follow TFP chemical advice, they should NOT get a cloudy pool. About the only time one *might* get a cloudy pool is when you add calcium on the same day you use a chemical that adjusts pH. Those two should be on different days.which can all result in cloudy pools.
There is no reason to do a full panel daily. FC and pH daily, full panel weekly is plenty.3. I would continue to take daily readings of ALL items for at least a month so that you can familiarize yourself with "normal" readings.
Her cell makes 1.9lb/day. It is very large for her pool.Make sure that your SWG is rated for approximately 2X the size of your pool.
There is no reason to do an acid demand test. Manage pH, and use pool math for calculating muriatic acid additions.I would also look at the Taylor test kit on how much acid to add if needed.
There is generally, no reason to raise TA, unless it is below 50. Her fill water is about 80 TA, so she will not have large TA swings.6. After your FC/CC/PH are in line. Now it is time to focus on Alk. Decrease or increase as needed.
She can simply manage pH and ignore TA (test for it, but don't "treat" it). Follow this:
- When TA > 80: When pH gets to 8.0, lower your pH to 7.6. pH will rise. When pH gets to 8.0, lower to 7.6 again. Over time, TA will come down on it's own.
- When TA is between 60 and 80. DON'T lower pH below 7.8. pH will be fairly stable between 7.8 and 8.0. Just keep it there and don't try to lower pH more than 7.8
