- Jun 24, 2021
- 16,160
- Vinyl
- CircuPool RJ-60 Plus
No, but if dirty in sight glass, and filter pressure is rising, likely not the filter.You don't think there's something wrong with the filter?
Yes, if you didn't get the rain, your pool should have enough water so the water level is 50% in the skimmer.Should we start filling with hose or wait for rain?
So, square 1.
Contractor filled, had debris and algae. He drained and refilled. Then he added what?
Did he clean it before the refill? Don't know why there is so much debris if he cleaned and refilled.
Did he empty the pool?
Where did the fill water come from and do you know your water rates?
7600g isn't a bad refill, and potentially a good option at this point. My water rate is $1.75/100gallons so a refill would be $130.
