- Jun 24, 2021
- 16,151
- Vinyl
- CircuPool RJ-60 Plus
Going out of town bad timing!!!Why not tomorrow?
I’m leaving at 9:30 am. Home now but pool is only 1/2 filledI don't want algae in this pool. What is your available schedule for working on this pool tonight and tomorrow?
I'll get you setup with what you need to do...
I was going to test first then do Pool Math to get to 50? Didn’t know if the remaining water in the bottom would affect?Go ahead and add 1ppm FC if the pool is 1/2 full. Seems like it will be filled in the morning. Test and add TO 2ppm in the morning when full.
Hang the sock at least 6" out in front of a return, you don't want it to touch the sides. After 30 minutes, he can squeeze, squeeze, squeeze to get it dissolved.
How many CYA ppm are you going add?
Once the sock/tshirt hits the pool, it is safe to raise FC to range for your CYA. Link-->FC/CYA Levels
50 is great to start. Slam will be short and easy if necessary. I'd test, nothing like practice...my guess is you will fill the tube and the dot will be clear.I was going to test first then do Pool Math to get to 50? Didn’t know if the remaining water in the bottom would affect?
Am I adding the 1 ppm now and 2 ppm when full assuming it’s 0 or are am50 is great to start. Slam will be short and easy if necessary. I'd test, nothing like practice...my guess is you will fill the tube and the dot will be clear.
Remember, it may take 24 to 48 hours to register. Once it is in the pool, treat the water as though it is 50.
For the avoidance of confusion. 1ppm for 7600 gallons.Add the 1ppm for a 1/2 full pool
Yup! We just did. It’s like 99% filled. Hubby is going back out in a minute to brush one more time, turn off spigot, and we will do the CYA & test to add more FC in the AM!NIIIIIIIIICE!!!
Go ahead and add the other 1ppm. Brush Brush to mix it up.
That hose water is CHILLLLLY!!!Did you jump in?
I don’t think I could be more thrilled for someone I don’t know! Congrats!!! And hats off to poolstored! You’re a champion!That hose water is CHILLLLLY!!!Gotta get it up to a toasty 85 by the time i get home Sunday!
