Hi TFP!
About two months ago I bought a home that had an inground pool installed approximately 6 years ago. Currently it’s using a sand filter and frog mineral bacpac system. There is a salt chlorinator mounted on the wall that still has power going to it but doesn’t appear to be used anymore.
At first we thought we loved the Frog system, however as the heat has started to crank up, I think the low chlorine levels have presented an issue.
#1 - we are going through bacpacs every 4-5 days.
#2 - last week, green algae started to appear on the walls.
So, I did what any good new pool owner does and took the water to Leslie’s to test ( I know, I know)
Chlorine/FC was .14 ppm
Alkalinity was 0
Ph was 6.4
CH was 49
CYA was 87
Phos was 567
Sales guy said that the algae grows from phosphates so sold me some nophos to put in the skimmer. He said put 40oz in on Friday night and then 48 hrs later, backwash and put in the rest (that would be tonight)
After doing more research that night, I came to the conclusion that I needed at least .5 FC even with the frog system. So I went back to Leslie’s and they advised me to add 30lbs of baking soda to help with the alkalinity & ph then to use their “chlorine brite shock” to increase the chlorine levels 2 hrs after introducing the baking soda.
So I did all of that, after applying the baking soda the pool turned cloudy (duh) and then after the “shock” the water started to turn a clear green. This morning (Sunday morning) I woke up to a bunch of brownish gunk at the bottom of the pool that my robot vac seems to have no problem cleaning up but the water still is very cloudy and a clear green. Before the algae started to form, our water was crystal clear.
So, I’m trying to see where to go from here. I don’t want to keep following the “Leslie’s plan” but also not fully convinced to go off of the frog system yet. My first question is should I apply the second dose of the nophos tonight? Second question is do I SLAM from here or give it a few days to see how all of the stuff I did impacts it and retest with a quality kit?
Alkalinity was 0
Ph was 6.4
CH was 49
CYA was 87
Phos was 567
