Alright guys I’m back. If I refilled the pool redid the numbers and added chlorine according to the app to do a SLAM. I tested the water and my FAS-DPD and it’s still not turning pink
Not enough chlorine then. You should also add stabilizer to avoid having the sun burn off all your chlorine too fast which sounds like maybe what happened.Alright guys I’m back. If I refilled the pool redid the numbers and added chlorine according to the app to do a SLAM. I tested the water and my FAS-DPD and it’s still not turning pink
I did add stabilizer as the app said as well I did all the tests my CYA was 0 cause of course I drained it, I added a gallon of cya liquid into the pool. It was a horrible green this morning and it just cleared up a lot this afternoon. I’m trying to upload a picture of a part in my pool that I don’t know what it is but it keeps saying file is too big so bare with me. I hate doing anything with technologyNot enough chlorine then. You should also add stabilizer to avoid having the sun burn off all your chlorine too fast which sounds like maybe what happened.
Bperry, the little bit of water that was left was a lot of algae and I scrubbed a lot of it off the sides, could that be why it ate up the chlorine as well? I appreciate you helping me I feelI did add stabilizer as the app said as well I did all the tests my CYA was 0 cause of course I drained it, I added a gallon of cya liquid into the pool. It was a horrible green this morning and it just cleared up a lot this afternoon. I’m trying to upload a picture of a part in my pool that I don’t know what it is but it keeps saying file is too big so bare with me. I hate doing anything with technology
If your test says there’s no chlorine and the water was green yesterday get some more chlorine in there ASAP.I did add stabilizer as the app said as well I did all the tests my CYA was 0 cause of course I drained it, I added a gallon of cya liquid into the pool. It was a horrible green this morning and it just cleared up a lot this afternoon. I’m trying to upload a picture of a part in my pool that I don’t know what it is but it keeps saying file is too big so bare with me. I hate doing anything with technology
Approx 9700 gallonsKeep adding a gallon at a time until it registers on the FAS-DPD test. Also check the CYA once a day until it registers?
how large is your pool? Your signature doesn’t show that.
Which ones?Can you post the number you tested? so we can see what you are dealing with?
It’s not a dumb question, that is a water heater for the pool bathroom that’s adjacent to the pool pump closet shindig.This maybe a dumb question, but... it that water heater for your house?
All of them. Everything you test forWhich ones?
That helped thank you!He's asking for new numbers after the refill so we can help more specifically.
Please do be sure to read the article for the SLAM Process carefully - it's not a one-time dump of chlorine, it's a process of maintaining the chlorine up at SLAM level by testing as often as you can (at least 2-3 times a day, up to once an hour or so) and adding more chlorine to top it off. Keeping the chlorine up at that level is what will kill off all the algae in the quickest and safest way possible.
This picture may be betterI dumped hella chlorine in there and re read the SLAM article as suggested. I’m an idiot sandwich. As far as my pool equipment goes, I’m still trying to figure that out so bear with me. I have an 11 month old that is trying to show me that she can in fact out herself in dangerous situations at all time. I do have a question about my skimmer, it looks like parts are missing. There’s a basket sitting on top and in there there’s just two cylinder shapes. I tried to get a good pic but I suck. (Please see idiot sand which reference above.) how often do cartridge filters need to be changed?
