Badtzlenday
1
San Francisco Bay Area
  • My vac sweep is not working. Thought it was the pump again, but have tried a number of things which have not resolved the issue.
  • I've cleaned the pool side filter and two of the pool equipment filters, along with the Polaris vac-sweep filter cartridge. With the sweep hose disconnected and the system indicating the pump is on, yet there is only a trickle of water coming out of the disconnected sweep hose.
  • Replaced both booster hoses When I disconnect the booster hoses from the booster pump a lot of water comes out.
  • Replaced the discontinued Pentair LAO01 version with the two different, and new, Afras AF75 ones. Still not working. Can't imagine two consecutive new pumps both failing along with the original LAO01.
  • The Aqualink RS 6613/6614 control panel light for the cleaner is solid green and the control panel in the house shows it is on.
  • Tried turning off the main pool breakers for a few minutes to see if a reset might work.
  • The main pump and solar system seem to be working fine and even the controller side breaker switches to the booster are fine. So it seems like there is juice to it.
  • However, it does not seem like the booster pump is on as there is no vibration in the booster pump or the booster pump hoses when the system indicates that it should be running.
Welcome to TFP.
Show us pictures of your equipment pad and your pumps and plumbing.
Are you sure you do not have the suction and return reversed on the booster pump?
Your problems are in your plumbing not in your Aqualink controls.
