BMOP
foo.c
103
Georgetown, TX
Final bid received! It's based off the old drawing but close enough to get an idea of what my final cost will be. (Not expecting it to be 100% correct though, adding a 10% fudge factor.)
I called the excavator and he's ready to start ASAP. Not sure if that's good or bad. He's coming over tomorrow to verify access and what not.
foo.c
103
Georgetown, TX
3 days of jack hammering, but it's starting to wind down. Excavation/steel company owner says the steel will go in Thursday or Friday depending on if the plumbers want to do plumbing before or after steel.
I might have a pool shell by next week. I'm going to need a coupler and another hose to water the gunite.
gnr5
153
Miami, FL
@foo.c im thinking of going OB as well. Inposted a thread but no amswer so far. I was wondering how are you dealing with the smaller items such as the main drain cover, or the valves? Is each sub providing material? Skimmers, did you buy it yourself?
gnr5
153
Miami, FL
The guy that did my design spec'd it all out and the plumbers are supplying the hardware. I'm more of a manager of the process.
Got ya
1. By designer, you mean the engineer that did the plan?
2. Did this person help you with the equipment?
3. When you call the plumber did you just send them the design/plan or did you have to specify each part?
Your dig is looking amazing!
foo.c
103
Georgetown, TX
I sent them the design and then they broke it down and itemized it and sent me a quote.
I'd say to find a plumber that has done a lot of pools and give them a call. So far everyone I've called has been very helpful.
Reactions: kimkats
foo.c
103
Georgetown, TX
He's only 13 and almost as tall as me. Makes me wonder if I should have spec'd a deeper pool, LOL.
The outfit handling, coping, tile, plaster, and decking is 2-3 weeks out, so it looks like at least a week, maybe 2 of nothing happening. Bummer.
JJ_Tex
1,544
Prosper, TX (DFW)
Our 13 year old almost 6' kid is also only getting a 6' deep pool to jump into. I think he will survive. It will seem deeper once you get coping in, and even deeper if you have a raised wall or something else higher for him to jump off of.
By the way, 2-3 weeks out for coping, tile, decking etc seems like perfect timing. I assume you have rebar, gunite, plumbing and appropriate inspections lined up for the next 2-3 weeks?
foo.c
103
Georgetown, TX
He'll definitely survive. First world problems ...
Rebar and plumbing are supposedly going to be done this week. Electrical and then gunite early next week. So if those go perfectly there could be some downtime. I live outside the city, no permits or inspections are required per the county. (There is a certificate of compliance which is more about flood plain issues and I'm not in the flood plain.)
