BMOP
foo.c
103
Georgetown, TX
We have a mix of elm and live oak. The elms drop their leaves this time of year and the live oaks drop them in the spring. Outside of those times I think it will be tolerable.
My garage is always full of leaves when the elms drop and the closest tree is probably 25 feet or more away. I don't think cutting them down is going to make a meaningful difference.
Reactions: kimkats
Newdude
1,512
NY
I took down 14 oaks in the general pool area so nothing falls directly into the pool. I watch my other leaves Float 100ft or more from other trees and still make it into the pool.
foo.c
103
Georgetown, TX
Awesome! Is this for the entire build? Do you have a comparable PB quote and total price you can share with us?
Yes, everything. I don't have an apples to apples comparison because my pool is 25% bigger than theirs, and I added a patio extension, Hydrazzo instead of pebble, etc. Basically whatever your budget is, you'll find a way to spend.
I will say I was able to undercut the most expensive bid by a little bit, but I have a bigger/better pool. I'm actually higher than the least expensive bids, but again they were smaller pools and I didn't have a lot of confidence in them to stay on budget and deliver a good product.
foo.c
103
Georgetown, TX
Yeah, I noticed it after they were done and left. Plaster guy thinks it will come out either on its or with some brushing. If not he says he can have a diver polish it.
I got my shop vac out and sucked up all the water and debris.
foo.c
103
Georgetown, TX
I read somewhere you can rub a puck on it and it will come off. Will try that if it's still there when I eventually get in.
Spent the morning setting up the skimmers since apparently that's the pool builders job around here, or something ... fun! All done now and about half-way full.
kimkats
42,195
Tallahassee, FL
Don't want to try the puck just yet. That plaster needs time to harden and cure for a while. By the time it is warm enough to not play polar bear hopefully it will be gone by then!
Kim:kim:
Nectarologist
534
New York
If you plan on buying a robot, it will take care of the leaves. I have a Doheny's Discovery powered by Dolphin and it gets acorns and the oak leaves which as you know are large and thick so they don't crumple easy. You pool is beautiful. Enjoy it!
Reactions: foo.c
foo.c
103
Georgetown, TX
Pumps running! Still a bunch of little things to do like programming schedules, in addition to the start up. I wish it would stop raining.
It's a little bigger than planned. It's ~21k gallons based off the meter.IMG_5595.JPG
foo.c
103
Georgetown, TX
Hmmm ... I took the measurements, used the pool calculator and it said to lower my TA I needed to lower my pH to 7.2 and to do that I need 58oz of 31% acid.
So I did that and re-tested ... nothing changed. Maybe I didn't wait long enough? I don't want to overshoot it so I guess I'll wait.
kimkats
42,195
Tallahassee, FL
Nothing as far as the pH or the TA? The TA will lower slowly. The pH change should show as soon as 15 mins if the pump is on and moving the water good.
ajw22
11,315
Northern NJ
What plaster startup guide are you following?
The CSI is not applicable to new plaster finishes under 30 days old. It is actually necessary, to achieve a smooth and dense surface, to have about a +0.5 CSI during the first 30 days. This is because the plaster (cement paste) surface contains about 20% calcium hydroxide, which is somewhat soluble in balanced and slightly positive CSI water and can be dissolved away. The plaster surface needs to be "carbonated" before the CSI should be lowered to the acceptable and balanced range. And that generally is achieved during the first month under balanced water
foo.c
103
Georgetown, TX
I'm using the one on the manufacturers website: http://clindustries.com/MSDS/Start_Up_Procedure.pdf
These are the 2 relevant steps from the Day 1 instructions:
Step 2. High total alkalinity should be lowered to 80 ppm (mg/l) using pre-diluted Muriatic Acid (31-33% Hydrochloric acid). Always pre-dilute the acid by adding it to a 5 gallon (19 L) bucket of pool water2.
Step 3. High pH should be reduced to 7.2 if the alkalinity is already 80-100 ppm (mg/l) using pre-diluted Muriatic Acid (31-33% hydrochloric).
I'll be re-testing here in a little while.
foo.c
103
Georgetown, TX
Guess I was too impatient yesterday. This morning the pH is 7.2 and TA is down 40ppm to 140ppm. Should I leave it alone until pH rises again, or keep dropping TA and then get the pH up?
