I hear you!! There are a quite a few things that did not get done this summer due to the heat. So not worth getting heat sick from!
Thank you for the reminder post!!!Quick question for safety, did you connect a bond wire to the stainless steel scuppers, previous pictures did not show one. If you did not i would suggest stopping and doing the correct bonding before finishing up that area.
It just looked "off." Better to fix now than have it bother me later. I told the wife this afternoon that it wasn't the first thing I've done then redone on this pool, but hopefully it will be the last. I should be able to ☑ off some projects here pretty soon...?So how did you just happen to notice it? Were you just sitting there thinking about all of the wonderful but hard work you had done THEN saw the boo-boo??? I have a sad BUT also a glad for you and your pool. It will get done and it will be done RIGHT in the end even if there are some steps backwards!
