So, I'm new to owning a pool (installed late last year)... and the recent chlorine shortage is making me want to ditch my tablet feeder/bottles of chlorine and go straight to SWG. My plan was to get my CYA to ~30 or so with stabalizer, then raise it to ~50 or so with pucks, and then use liquid... And swap back to the pucks just to raise CYA as needed. But, chlorine seems to be in short supply and $$$ this year. (I did get like 50lbs of pucks last year - which should buy me time - but using 7.5% bleach at $4-5 per gallon because it's all I can find locally)
I'm thinking of the Circupool Universal 40. My AGP/All resin pool is about 21K gallons.
1) I do have a 20A accessory circuit that I would likely tie into, instead of hooking it inline with the pump. All timers/breakers are inside my basement, about 225' away, and I don't want to have to pull another $500 worth of copper.
2) I should have room on my pad, but I'd have to get creative in mounting. Nothing that PVC and a new post cant fix.
So, my questions...
1) It has a flow switch. Does it *need* a timer as well? My plan would be to simply plug it into the 120V receptacle, and leave it there. (Yes, it is GFCI'd). Wouldn't the flow switch turn it on and shut it off with the pump? What would the disadvantage be? (Other option would be to purchase another timer and leave it outside, but make sure the two timers are synced up pretty well... or use something like a Sonoff WIFI switch that I could add to my home automation if the current draw isn't too high)
2) Do you know the current draw for it?
3) About how big is the control unit?
So, my questions...
