- Dec 26, 2016
- 34
- Plaster
- CircuPool RJ-45 Plus
Sorry for a basic question, but want to get confirmation I can do this myself.
Like everyone else, I'm having to switch to SWG due to scarcity of chlorine. Pool service is saying they can't get to me until mid-July and that an estimate can't be provided because prices will likely increase by then. So I'm planning on buying a Circupool RJ-30 for an 18k gallon pool and installing it myself. Plenty of room for the plumbing of the salt generator. But I do want to wire this so it turns on only with when the pump turns on.
Currently my Pump, Pentair Intelliflo VSF, is connected to the left manual timer in the picture with no timing tabs, so acting just as a switch if I ever need to manually turn it off. My Polaris pool cleaner pump is connected to the right timer with tabs. I'd like to connect the SWG to the left timer and connect the Pentair pump to direct power. My plan is to use the manual tab timer to control the SWG with some time cushion around the pump's timer.
Is this easily doable as a DIY? Any instructions on how connect the pump to be hard wired to power from this 2 timer configuration?
Thanks.
Thanks.
