Turbo1Ton
- Dec 26, 2019
- 1,995
- Plaster
- Pentair Intellichlor IC-40
Not sure what a tile job is going to do to correct the coping. That white strip goes over the top/face of the tiles to cover the joint between the coping and the tile. I have one on mine, except it is grey. As far as I know, it is built into the coping forms and gets left behind after the pour.
You've got to be happy with the end result, as Dirk and others have stated. If a tile job will make you happy, and you can live with it, then go for it. I wouldn't be happy at all with that. Not sure if the PB is thinking the tile job might detract from the poor finish on the coping, or what?
--Jeff
--Jeff
