Awkward backyard build
kimkats
37,593
Tallahassee, FL
WHAT A MESS!!!! but it will all be worth it in the end!!
sighhhhhhhhh why don't they listen better??? GURRRRRRRRRR for you!!
dorgan
128
Rockledge, FL
Ok forms is all set as of last week. Also now because of difference in elevation there will be a step up on each side of the pool. (Also added cost).
Anyone have a step up on each side of their pool? If so, do you also have baby gates? Wondering how that will look.
Pool form survey was done today, hopefully we can get results tomorrow/Wednesday and move to next step by end of week/early next week.
Also had to take down the shed to make room for the pool equipment as putting it under the kitchen window was a no go and to the left of it would have limited adding additional equipment(heater) in the future.
dorgan
128
Rockledge, FL
dorgan, do you have a pic or drawing to show what you mean by "step up"? I am not sure what you mean.
I don’t, but maybe if I put it another way. So our addendum states the following items
20’ 6” raised beam + deck
13’ 12” raised beam + deck
dorgan
128
Rockledge, FL
Had to take the shed down to have better placement of pool equipment, other it would have been to close to the pool. We also looking at having the A/C unit moved. Likely going to put the pool actually behind/next to where the shed was, but we weren’t using the shed for much and I am thinking of extending patio space as well.
97908
97909
97910L
dorgan
128
Rockledge, FL
Found out our roof has hail damage. So after getting that replaced in the next couple months I am thinking of installing a solar pool heater myself. Anyone done this? I assume the hardest part is the plumbing which would consist of a couple two way valves and a couple check valves besides the runs from the pump.
