Awkward backyard build
dorgan
175
Rockledge, FL
OK so we got the updated build plans. I guess the city is making them put in ??swales?? not sure what that is or how it will look, i need to follow up with the PB on that one.
kimkats
48,179
Tallahassee, FL
Big step forward!! SWEET!
Share a pic of where this pool is going so we can see what you are dealing with. I wonder if the swales are to slow water down???
dorgan
175
Rockledge, FL
They are definitely to slow down water, I am in Florida and my backyard is pretty flat. I am in LA this week on a business trip, so I will take a picture once I get home
dorgan
175
Rockledge, FL
Th first pic is from the back sliding door. The pool equipment will be put off to the right up against the house but far enough from the gas meter to be in code.
The second pic is from the side door where the fresh new patio will go to for this year. We’ll bring the patio up to the sliding door at the rear of the house next year after we take down the giant oak tree. Will be sad to do as it helps keep the house cool, but it’s too close to the house and is already impacting the cement and foundation back there.
I am really concerned about what the swales will look like around the pool, and need to call the pool builder to see if there are options.
dorgan
175
Rockledge, FL
Unrelated note: Trying to make posts from mobile phone is really hard now that there is no Tapatalk integration. Anyone know if there are mobile app plans in the works?
Reactions: Mbkemp
kimkats
48,179
Tallahassee, FL
dorgan, this new site was made with mobile devices in mind. Most people have been saying it is even easier than TAT. Can you share what is giving you trouble and maybe someone can help with the issue.
Okay so I have looked and looked at your yard. You don't have room for much of a swale at all. I would have the PB come out and walk you through what he is talking about and why. Take notes and share them here so we can see what he is talking about.
Big tree-I would think about taking it down NOW. It will be easier to do now then after the pool is in. You will also like the fact you will not have to deal with the leaves!
Kim:kim:
dorgan
175
Rockledge, FL
Kim:kim:
The pictures are a little deceiving as the fence along the back is a good foot or two inside our property line. You have to look at the last building plans I posted.
Regarding the tree, it’s about $4,500 to get it removed right now, so we’re holding off until next year.
dorgan
175
Rockledge, FL
Do not forget the overhead power will need to be buried.
Hence the flags in the yard ;) Electrician will be here on the 12th to dig the trench and put in the conduit. Then he'll coordinate with local power company for the cut over date... Power line has been our #1 priority since singing with the pool builder.
Leebo
Admin
10,507
Eastern Ohio
We’ve got the software automatically setup to reduce the file size as did Tapatalk. As long as the files aren’t above 5MB(non HDR) they’ll be optimized and resized. Both of your photos above have been reduced in size to roughly 400KB.
dorgan
175
Rockledge, FL
Ahh ok I think for the third I tried to take I noticed HDR was off, so I set it to auto. Ok good to know
A1Texan
132
Austin, Texas
I had to get my overhead main power-line to the house buried. That alone cost me $7k. They had to go 120' down and around the property line. Had to be done though if I wanted a pool :)
I'm looking forward to your build. Have fun!
dorgan
175
Rockledge, FL
Yup mine has to be done as well, luckily its only costing $2,300 for that piece.
Phx_Jay
150
phoenix
That is a very small Baja ledge. It can't be bigger then about 7' X 5' right? Besides pool depth, a lot of people wish they had put in bigger Baja steps. I probably would have made that bigger and then curve off of it to the connect to the deeper end seating...basically a bench all along one side of the pool. How deep are you going with the Baja ledge?
dorgan
175
Rockledge, FL
Are you doing the work or letting your wallet do it for you? That is a LOT of digging right there!
my wallet. I've got enough going on inside the house fixing all the things the previous home owner half butted, which currently includes floor transitioned that were put in place via caulk.
