Hello, I recently had to remove my pool deck and found I have a unused 1 inch line that used to run a pressure pool cleaner. Since the line is already in the wall of the in ground pool I would like to make it an auto fill. The line goes up from the pool wall then does a 90 right below the waterline. I am unable to get to the line as it’s in the concrete of the pool wall. With this I am unable to have a straight equalizer line to the auto fill. Since it comes up does this mean it will not work for what I am trying to do? It’s my understanding that you need a straight equalizer so you don’t get an air pocket for the leveler to work. Any advise.
