Audio planning
Cephrael
162
Massachusetts
So after lots of thinking and research I went with th monoprice. 2 x 2.1 system and 4 additional satellites. It was hard to beat the cost knowing that they are probably going to take a beating and at $25 for two satellites it'll be cheap to fix. Now to figure out the amp. Sonos is definitely the front runner, but can it provide enough power for 8 satellites and two subs? I want enough power to be able to annoy my neighbors. We get along fine, it was just the best way to describe how loud I want it. And not all the time, just occasionally when I'm the only one around and don’t want to talk to anybody.
Cephrael
162
Massachusetts
The Sonos amp should be fine
Ok.
I noticed you said you ran yours in parallel. Do you think that helped the system sound better than running the 2 - 2.1s in series? I have the opportunity now to run the wiring prior to the patio being done. I think I could at least run the subs wire now and then figure out exactly where I want the satellites later,
bdavis466
Platinum Supporter
Aug 4, 2014
5,172
San Clemente, CA
The satellites get powered off the sub so knowing the subs placement would be ideal. You might try starting out with just the 4 satellites...I can easily upset my neighbors :ROFLMAO:
With the way the subs work I don't think wiring in series is a good idea or even possible.
Reactions: Cephrael
jimim
2,517
NE/Pa
You can’t wire in series with these setups.
If u have 2 subs you can put 4 speakers on each sub to have 2 sets in series.
Adding more speakers with these setups don’t make them much louder. The speakers are directional. So if you want the neighbors to hear them point them that way. The number of speakers is based on areas You want to light up with sound.
Cephrael
162
Massachusetts
On the monoprice site, they recommended using two of their unity 450w amps, which provides a little bit more power than 2 of the Sonos amps if I’m reading the specs right.
I didn’t realize that the satellites had to come off the sub. That will make wiring a bit easier. I was planning on doing two separate zones for each end of the pool. So one sub and 4 sats at each end with the subs in a corner and two sats to either side.
I realize they are directional. It was more metaphorical of how much sound I wanted in the pool area.
Cephrael
162
Massachusetts
The subs would be better closer to the center of the yard in between the satellites
There’s going to be a 12 foot long wall by 30 inch high wall going down one side of the pool. Would that affect the sound coming from the subs? If not, I can put them behind it, or one towards either end of it.
Lots of pics on my build thread if you want to look and make some recommendations.
bdavis466
Platinum Supporter
Aug 4, 2014
5,172
San Clemente, CA
The wall will sit 30 inches above the pool and the subs on top of that? Or the subs will be 30 in below the pool?
tank47
66
NJ
Did you decide on sonos? I have a 15% off code if you still need to purchase. I am thinking I am going with the same set up.
madtv126
90
Fort Mill, SC
The wall will create a pretty big issue for sound reflection. Since sub woofers sound is omni directional it does not really matter except for the subs proximity to the wall and your neighbors. I think you will find that the satellite speakers need to be carefully placed in front of the wall or on top to project sound into the pool area. My current set up does not have a sub due to proximity to neightbors and I use 2 rock speakers and 2 satellite speakers close to the spa to listen to the music. My sound is quite loud and also flows into my neighbors yards as any sound outside cannot be adequately directed.
Reactions: Cephrael
bdavis466
Platinum Supporter
Aug 4, 2014
5,172
San Clemente, CA
This is a very true statement. The directional speakers cannot be heard outside of my yard, even at a very high volume but the bass travels. I was actually surprised at how loud it was at my neighbor's house...
You may think you have great taste in music until you only hear nothing but the bassline... I don't think anything sounds good like that🤷🏻‍♀️
Reactions: Cephrael and tank47
Cephrael
162
Massachusetts
I like to use this to test out my woofers
Bass test
My closest neighbors are about 200 ft away, so not too worried about the bass bothering them much. Probably won’t get the system installed until next year at the rate my build is going.
