Sammy2
0
I searched that company on Google. They manufacture electrolyte cells. I suspect they manufacture them for Hayward but didn't have time to further research it.
Does anyone on here have any experience with the generic version of the T15 salt cell? They are much cheaper. Are they any good or should I just spend more and get the AquaRite brand?
Their current price is $458.99 (some have it cheaper).I considered a generic brand however I purchased a new Hayward t-15 cell from Pool Supply World last year. I got 7 years out of my original cell so I figured I should go back with the OEM![]()
SWG Cells should be sized to twice your pool size. T-3 is for up to 15,000 gallons and is insufficient for pool your size. The T-15 you had is sized for up to 40,000 gallons, so you'll essentially need to triple the run time of your SWG to generate the same amount of chlorine.
You can use T-9, it is sized for up to 25,000 gallons. That's probably a reasonable compromise given your pool size. My pool is slightly larger than yours and I have the T-9 cell. I run my SWG at 50-60% in the summer with pump running for 10-12 hours. As comparison, with T-3 it would have be at 100% (constantly on) and pump would probably have to run slightly longer. This will exhaust your cell much sooner and cost you more to run your pump.
