Thanks to all for the assitance so far! Very much appreciated.
A couple notes that were left TBD on the design...
Plumbing:
Dual Skimms, in the case of our primary wind direction, they are at the deep end.
Strip drain with flush top. I see opinions here vary, but we have always found one useful for circulation, especially when bringing the water temp up in the early spring.
Returns are situated on each of the remaining sides. Hydro loop to balance flow.
Fill/Level is TBD, but I am leaning toward the Paramount. Due to some higher winds we will not use the flush valve style as they have proven problematic in our previous pools. Wind is always an issue here and we are close to the mountains...
Suction/Returns to be minimum of 3". I am researching the value of 4", cost vs friction loss of 3" and having to adapt it down at the pad. Any inputs are certainly welcomed.
Equipment pad is approx 22' to closest edge. Pool is approx 20'x39'.
The spa is at the furthest point from the equipment, about 80' or so from the pad.
Control/Sanitation:
Pentair Intellitouch, 8 station, with screen interface. Its about 25' from the Router, so we are looking at direct connect with LAN in lieu of wifi.
Pentair IC 60 SWG.
Designer slated a suction vac which we will likely leave in but Im looking at robots.
Heater:
NG 400K Pentair, with a By pass. Thanks TFP for that tip!
Solar - with 350+ days of sun, its an economical way to warm the water in the spring/fall. Single story house, plenty of concrete tile surface area.
Lights/water feature:
W/F is slated to be Brilliant wonders, 96".
Lights will be 1.5" CMP LED all around.
Considering adding a CMP LED/bubbler at the wet deck/ baja shelf.
Spa:
Finalizing the jet layout now. Planning on using the Waterway Manifold in a couple seats, plus some singles throughout. Also planing on a CMP Array (4x 1/2" jets).
We have 2 XF-VSF pumps spec'd for the jets and an air pump as well. Looking into adding the zoning noted by Roy, with automation. Only a handful of plumbers here have done this, so its currently a work in progress.
Its a complex spa layout for sure, but the goal is to have something more than what most PBs here provide...Specifically, a basic lounger, some seating with multiple jets, some foot jets. About 24 jets total.
