Another Vegas OB
SinCityCJ
101
Las Vegas
That is one beautiful pool. You should be proud.
Thanks!, Blessed, Proud and tired!
Wow, are those some sort of terrazzo pavers? Looks excellent!!
Thank you! We installed them ourselves as an option to save a little cash later in the project. A ton of work, but we are happy with the results.
They are actually concrete, pressed and polished. Made by Artistic Pavers, this is their Desert Series, Cool White (made in AZ, btw).
I would highly recommend them for anyone with intense sun. Its been 110+, no shade until late day, and you can walk on them comfortably in bare feet. I have one section of exposed aggregate to remind us of how hot concrete can get in the sun here.
SinCityCJ
101
Las Vegas
Thanks Roy!
We have enjoyed it thus far. The waterway jets worked out well. We did have to adjust Spa wall thickness a little. Two whisperflo pumps and one air pump are adequate flow for the number and size of jets. The waterway jets take some time to install, but well worth the ability to varu the flow. Working on dialing in the 1” bench jets now, need smaller eyeballs for them but all on backorder at the moment.
Also been thinking about adding a stand alone booster for the sheer. Its a bit of a water hog with everything running.
Now its on to landscape!
SinCityCJ
101
Las Vegas
SinCityCJ
101
Las Vegas
The spa is called North Sea blue, 1*2 glass, from Master Tile. The waterfall is porcelain , Montecino Jasper, in black. Those are 16”*32” on the waterfall. We tried to bookend them as best possible so it appeared to be a slab. We got it at Floor & Decor, but Arizona Tile had a couple that were very similar. The Jasper was the last choice but we are happy with it.
Reactions: BUT ITS A DRY HEAT
