Was about an hour late for my next measurement, but the FC was down to 14 and I topped it back up to 16. Can clearly see the bottom of the shallow end, so just waiting for the cloudiness to clear up on the deep end. Feel like we're almost there!
@cowboycasey My filter pressure question is completely unrelated, but here goes. For the most part, my pressure hangs out at around 18psi, which seems a bit high (maybe not - and if that's the case, the rest of this may be moot). I've never actually seen it lower than that, and I rarely ever see it much higher than that, either. I backwash somewhat randomly, because I never see it get up into the 22-23psi range, which would be a 25% increase from 18. Last year, a guy at Pool Store Who Shall Not Be Named told me that the pressure was way too high, and it was likely because of the number of 90 degree turns in the pipes on the way back to the pool. I've attached a picture of the plumbing, so you guys can see what I'm talking about.
So I guess I have a few questions:
1. Is 18psi abnormally high?
2. Should I be waiting for it to hit 23psi before I backwash?
3. Should I redo this plumbing to reduce the number of 90 degree turns?
