- Apr 29, 2015
- 51
- Fiberglass
- Hayward Turbo Cell (T-CELL-5)
I know these types of questions get asked a lot, but I'm looking for a bit of guidance. I've always gone the "pool store" route for clearing up my green pool, with mixed results (including spending $2,500 on chemicals and algaecide in 2019 and not getting to swim in my pool a single day). Last year was a good year, but this year has been tough to get it going again, and I was tired of just giving them money with little results, so I decided to try the SLAM method.
Here were my starting numbers:
Free Chlorine - 7.5
Total Chlorine - 7.5
Combined Chlorine - 0
Total Bromine - 15
pH - 7.2
Total Alkalinity - 70
Calcium Hardness - 550
CYA - 70 (brought down from 90, two days before starting the SLAM).
I started the SLAM on May 2 and have been very consistent with it. I do not lose much FC, and usually only have to add once or twice a day (maintaining FC of 28 - it has never fallen below 23). The first few days, my pool turned from a very dark green into a much prettier emerald green, but it hasn't really changed much since then. I am seeing progress every day, but I have to look really hard for it. At this point, 16 days in, I still cannot see the bottom of the shallow end (although I can see the pool cleaner when it's in the shallow end) and the pool is still very green (see attached pic - it shows the pool cleaner in 3ft of water). I can see the jets clearly, but once it gets much deeper than that, visibility drops off fast.
If the answer is "keep doing what you're doing and be patient", I'm fine with that. But if there are tweaks I can/should make, or other things I should be considering, I'm all ears.
Thanks in advance.
Free Chlorine - 7.5
Total Bromine - 15
pH - 7.2
Thanks in advance.
