- Aug 20, 2020
- 7,758
- Plaster
- CircuPool RJ-60
For reference, I normally run mine around 1500rpm, occasionally faster if I run the waterfall. Theres generally no need to run it very fast, just enough to skim well, make chlorine, use the heater, etc.@Newdude ... that makes sense. Dropping down from the 3400 I've been running last 24 hours. I'm currently running at my normal high-speed mode... 2800 (unless suggestion to go down further... 2800 sits around 12 psi start and watching dial to hit 16 before clean).
Will also be running for about 3 hours/off 3 hours to allow better settling. It's getting better so fingers crossed I'll still be good for hosting event on Saturday.
May the pool gods be generous...
