You can test in about 15 mins if you make sure the pump is running. Brush the area you add it to help mix it in even better.
Kim
Kim
A few pictures might help illuminate the situation.
CLEAR green and CLOUDY green are often two different things.
How often are you testing and adding these days? Keeping the filter on 24/7? Brushing the sides and bottom at least once a day?
A slightly dirty sand filter works better than a clean one. That is why you add DE, to make it dirty. So do not backwash until you see a 20-25% increase in your filter pressure.
Take care.
